broadband speeds appauling!
craigy88
not even getting 4mb/s download speed, its pretty hurrendous to be honest, can anything be done about this or do i just have to put up with it? downloaded a 1gb file earlier and my download speed peaked at 520kb/s!!!!! surely theres something wrong?! anyone help?
Fixes: 136
Re: broadband speeds appauling!
I've run a few tests and I can't see any issues.
Your estimated speed is 3mbps and I can see from the BT Speedtest you ran your getting around 4mbps which is above that.
I think you may be getting confused between Kbps and KB/s. 520kb/s works out at around 4.1mbps.
 Matthew Wheeler
Fixes: 9
Correction:
Quote from: Matthew
520kB/s works out at around 4.1mbps.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
