turn on suggestions
broadband speed slow
- broadband speed slow
08-08-2014 10:45 AM
Hi my broadband speed has dropped again, I was previously getting around 7.6mb but when i check my line it says
Estimated line speed:
Current line speed:
5.8 Mb
its dropped to the same speed of 5.8mb when I last posted about slow speed in April a staff member reported the line had high SNR and reset it.
Thanks for your help.
Re: broadband speed slow
08-08-2014 1:16 PM
08-08-2014 9:41 PM
Hi I reset my router 15 minutes ago but it seems to be connecting at the same speed as before, no change.
11-08-2014 12:59 PM
Hi I checked my router today but the connection speed is still slow, The information from my router posted below.
Downstream Upstream
Line Coding (Trellis) On On
SNR Margin (dB) 13.1 5.6
Attenuation (dB) 31.0 16.9
Output Power (dBm) 0.0 12.8
Attainable Rate (Kbps) 10572 1260
Rate (Kbps) 6656 1251
Downstream Upstream
