broadband slow and getting slower
- broadband slow and getting slower
04-06-2016 4:23 PM
speeds have been getting slower and slower last few months
currently sync'd at 2100 kbps
PlusNet Current line speed:1.4 Mb
bt speedtests max out at 1.33 kbps
why is it so hard for plusnet, your part of bt, damn near as expensive
and a forum that goes belly up when you try to post new topics, awesome....is that to deter posts?
Re: broadband slow and getting slower
04-06-2016 5:17 PM
A line test I've just performed shows a line rate of 1852kbps so I would expect a little better.
Were you connecting over WiFi or ethernet when you ran that particular test?
We're not aware of any issues, what happened?
04-06-2016 6:23 PM
not sure who's line you tested but I doubt it was mine with speeds like that, still getting same slow result here on lan, not wifi
as for the dodgy forum, I write out my post, click post and I get a white screen, damn annoying
04-06-2016 9:45 PM
Login: admin
Password:
> adsl info --stats
adsl: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 13406 Kbps, Downstream rate = 3276 Kbps
Path: 0, Upstream rate = 434 Kbps, Downstream rate = 2100 Kbps
Link Power State: L0
Mode: ADSL2+
TPS-TC: ATM Mode
Trellis: U:OFF /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 4.1 6.0
Attn(dB): 67.0 37.8
Pwr(dBm): 17.3 11.8
ADSL2 framing
MSGc: 59 29
B: 32 15
M: 1 4
T: 2 2
R: 12 16
S: 0.4951 4.5714
L: 727 140
😧 64 2
Counters
SF: 5563712 282667
SFErr: 7992 4
RS: 723282670 1037585
RSCorr: 239405480 11642
RSUnCorr: 21589 0
HEC: 3782 3
OCD: 7 0
LCD: 0 0
Total Cells: 443511716 91648858
Data Cells: 38728821 2961512
Drop Cells: 0
Bit Errors: 0 179
ES: 7382 4
SES: 2 0
UAS: 19 19
AS: 89540
INP: 4.22 0.91
PER: 16.09 20.00
delay: 7.92 2.28
OR: 32.31 14.00
Bitswap: 453 22
Total time = 1 days 52 min 47 sec
FEC: 239405480 11642
CRC: 7992 4
ES: 7382 4
SES: 2 0
UAS: 19 19
LOS: 0 0
LOF: 0 0
Latest 15 minutes time = 7 min 47 sec
FEC: 1320989 87
CRC: 71 0
ES: 58 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Previous 15 minutes time = 15 min 0 sec
FEC: 2505795 170
CRC: 117 0
ES: 107 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Latest 1 day time = 52 min 47 sec
FEC: 8798091 554
CRC: 377 0
ES: 342 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Previous 1 day time = 24 hours 0 sec
FEC: 230607389 11088
CRC: 7615 4
ES: 7040 4
SES: 2 0
UAS: 19 19
LOS: 0 0
LOF: 0 0
Since Link time = 1 days 52 min 19 sec
CRC: 7992 4
ES: 7382 4
SES: 2 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
04-06-2016 9:51 PM
plusnet has current line speed as
bt wholesale speed test result
download speed 1.32 mbps
upload speed 0.37 mbps
latency 42.50 ms
Download speedachieved during the test was - 1.32 Mbps
For your connection, the acceptable range of speeds is 0.8 Mbps-2 Mbps.
IP Profile for your line is - 1.85 Mbps
Upload speed achieved during the test was - 0.37Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.45 Mbps
