bridging routers wirelessly
- bridging routers wirelessly
29-01-2013 2:17 PM
I have Thomson's router for the main broadband in the house and have wired another plusnet router to it and created a larger range. I would like to now bridge them wirelessly. Can anyone suggest an easy way to do this. Thank You. Alan.
Message 1 of 3
(1,068 Views)
2 REPLIES 2
Re: bridging routers wirelessly
29-01-2013 2:37 PM
You really are better doing it as you already have, a wireless link will be much slower as the bandwidth will be shared.
If getting a cable to the right place really is a difficult problem consider Homeplugs.
Message 2 of 3
(339 Views)
29-01-2013 2:58 PM
I use TP Link TL-WPA281KIT AV200 Powerline Extender with Wireless N Access Point Starter Kit to overcome my wireless issues
Dan.
Dan.
Message 3 of 3
(339 Views)
