bridging between 2 routers
- bridging between 2 routers
08-06-2011 1:48 PM
Hi
I'm using the Zyxel router supplied for FTTC and also have lying around a Thomson 585vn that I had tried out. Is there a way to bridge between these in order to extend my wifi network to my garage?
Message 1 of 8
(1,260 Views)
7 REPLIES 7
Re: bridging between 2 routers
09-06-2011 8:45 AM
Is that a "no" then?
Message 2 of 8
(781 Views)
09-06-2011 9:45 AM
This may be helpful
see "Botched up a home network and it's working!" under "Hardware" forum
dick:green Link added.
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Message 3 of 8
(781 Views)
09-06-2011 10:10 AM
Strat
how do you do that? add the link I mean
Message 4 of 8
(781 Views)
09-06-2011 10:15 AM
This is going to be hard without the forum creating a link.
Scratch that, it wasn't as hard as I thought!
Name you want to show here
Message 5 of 8
(781 Views)
09-06-2011 10:35 AM
I'll have a look at that. Ideally I'd like them to connect to each other wirelessly, but a cable (or homeplug?) would be a good second best.
Message 6 of 8
(781 Views)
09-06-2011 12:21 PM
If your like me you get most satisfaction from utilising kit lying around
if you Google "WIFI booster" you will see the kit you are thinking about. I think around £30 from Maplins
But if you have the cable and the router or should I say switch
Peter
Peter
Message 7 of 8
(781 Views)
11-06-2011 4:32 PM
Thanks Peter.
My son set this up now. He can access the internet from his Macbook in the garage as he wanted. router to homeplug, homeplug to router, and he has logged into the second router. I'm not entirely sure how he set it up, because I haven't had a look yet, but oddly the second router doesn't come up on the DHCP list of the first one. I'm not too bothered as it works.
Message 8 of 8
(781 Views)
