bras reset option
- bras reset option
bras reset option
11-08-2007 11:50 AM
Would it be possible for end users to have access to a button / script in the control pannel that coudl re-set a lines bras rate when it goes awol.
Just a thought.
I'm off to raise a ticket about mine.
A
Just a thought.
A
Message 1 of 4
(2,610 Views)
3 REPLIES 3
Re: bras reset option
11-08-2007 1:58 PM
No because it is BT that sets this. Actually its an automated system at the exchange which neither PlusNet or the user has access too.
Bras Profiles are updated dependant on line conditions. In the past when you sync lower, the Bras profile is adjusted downwards within 75 minutes and after resyncing back at your normal rae it would take 3 -> 5 days for BT to catch up again. This is changing so a profile change should only take a few hours to return back to normal in most situations.
Message 2 of 4
(777 Views)
04-10-2007 11:31 AM
Is there any suggestion of when this is going to happen? From recent experience it still takes 48hrs.
Message 3 of 4
(777 Views)
04-10-2007 11:53 AM
It has already happened but no sign of it actually making any difference to the time needed to restore your BT profile.
Possibly another theoretical solution that never works in practice!
Message 4 of 4
(777 Views)
