boardband BANDing problem
rpwd
Dear Joanne, would you please lift the banding for my broadband connect? the plusnet account page said it should be 5-8M. But now it is still 1M after the engineer changed the socket on the wall.
rpwd
Re: boardband BANDing problem
the socket has been changed. the broadband still goes off every 10 minutes. I am bearing with the painful connection now
jojopillo
Hi rpwd,
I've just changed the profile on our side to 9200 to allow for your new BT IP profile. You should see the increase shortly.
Jojo Smiley
rpwd
thank you so much, Joanne, Is there any thing I should do? Should I restart the router as well?
I will be back if the speed gets back to normal.
jojopillo
Nothing you need to do. Once it takes effect it will just drop the PPP session automatically Smiley
jojopillo
Thanks for your PM, glad to hear it's ok now Smiley
