bilion 7800n router on ppoe
- bilion 7800n router on ppoe
09-04-2011 9:26 PM
it will connect and work fine on ppoe without any isues what so ever
plusnet require and support a ppoa connection, which i would like to use if there were no issues
i have contacted billion and spent weeks with router info and connection settings being sent back to there head office to see if there is a hardware or firmware issue, they also there have a plusnet line and do not have that issue there withe this router on there line. . and all the people they have stating they have issues with ppoa connection on this router .our plusnet customers only .
no problems with any other isp llu or bt , so eitther it is some equicment at plusnet or bt equickment at some exchanges put only affecting plusnet customers.
can any one please shed some light on this matter
thanks for any help in advance
Re: bilion 7800n router on ppoe
09-04-2011 9:30 PM
10-04-2011 9:19 AM
both have the authenticasion as auto for sign in autthenticasion protocol
and as i said billion is only having this issue with ppoa with plusnet customers in the uk
one that does not work below
Broadband Username/Login name username@plusdsl.net
Connection Type / Encapsulation PPPoA /PPP over ATM
Virtual Path Identifier (VPI) 0
Virtual Channel Identifier (VCI) 38
Multiplexing method VC Based / VCMUX / VC-Multiplexing
but these do work below
Connection Type / Encapsulation PPPoE (RFC2516, PPP over Ethernet)
Multiplexing method llc-snap-bridging
10-04-2011 11:17 AM
There are a few other PN users with these routers and I haven't heard any others with this issue.
10-04-2011 1:57 PM
10-04-2011 7:25 PM
Most other European countries seem to use PPPoE, and the UK will probably switch over gradually.
Graham
11-04-2011 8:59 PM
but when your brodband supplyer states you should use this and not ppoe
and in some post in forum it is stated they will not provide support if not using the correct sign up settings
i would like to be able to do this and to find out why i can not do this
12-04-2011 11:04 AM
I see what you're saying about the broadband connections page (http://www.plus.net/support/broadband/help_and_setup/connections_settings.shtml) - I'll raise a problem on that to get it updated, thanks very much for the heads up.
12-04-2011 11:55 AM
Quote from: BLUECRUISER2 i am trying to find why my router will not connect easyily on ppoa, and if it will not connect if there is a dropped connection without a reboot of rooter each time
There's quite a lot of this about. See http://community.plus.net/forum/index.php/topic,78341.0.html and also several other similar threads on PN and other forums (Kitz, Thinkbroadband).
I was using a BT Voyager 2110 when this problem was occurring. This is the first time I've come across it with the Bipac 7800N, which I am using now on PPPoA with no problems.
With the Voyager I just left it set at PPPoE and there's weren't any repercussions at all. I was advised that it's almost certainly some incompatibility between the router and BT's exchange equipment.
15-04-2011 8:17 PM
I have a Billion 7800N running on PPPoA using 1.06b firmware with no problems, these are my settings - I've blanked out my username and static ip.
Steve
15-04-2011 8:28 PM
16-04-2011 9:01 AM
so there seems no idea why this is and by the look of it stuck with ppoe from now on
