better router
- better router
better router
24-03-2013 6:10 PM
Hi all looking to improve wireless range around the house, have the main computer wired but 3 tablets and phones wireless, I live out in the sticks about 5 miles from exchange so speed is only about 1.2 , can any one recomment a ADSL modem/router that will improve wireless range am using the 582n at the moment ,hope to spend about £50 'many thanks
Message 1 of 9
(1,667 Views)
8 REPLIES 8
Re: better router
24-03-2013 6:25 PM
You can get a BT Homehub 3 from eBay for less than £15....wireless performance should be better with that.
Or, I'd look at something like something from TP Link - maybe the TD-W8970? It's a Gigabit N router with lots of features.
Message 2 of 9
(736 Views)
Re: better router
24-03-2013 6:54 PM
Thanks Andy, the 8970 was one I was looking at, seems to fit the bill, a step up but easy set up
Message 3 of 9
(737 Views)
Re: better router
24-03-2013 6:56 PM
It's probably worth checking to see if fibre is coming to your area before buying a router.
ADSL modem/routers don't tend to be fibre compatible.
Message 4 of 9
(737 Views)
Re: better router
24-03-2013 9:14 PM
I'd doubt BT would roll out fibre anytime soon. It is going to be around 2020 when almost of the UK is fibre enabled either by cable or fttc and other ways i.e 4G phone masts. You can use BT openreach site to find if its going to be available anytime soon HERE
Jamie
Jamie
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up
Message 5 of 9
(737 Views)
Re: better router
25-03-2013 12:51 AM
Quote from: AndyH You can get a BT Homehub 3 from eBay for less than £15....
and they're fibre ready too!
Message 6 of 9
(737 Views)
Re: better router
25-03-2013 7:47 AM
A number of people have bought the Asus N66U and a thread specifically for this router is running
Message 7 of 9
(737 Views)
Re: better router
25-03-2013 8:21 AM
Think the Asus is fibre only kelvin, have ordered the top link, many thanks all for opinions
Message 8 of 9
(737 Views)
Re: better router
25-03-2013 9:57 AM
I expect the ASUS would have worked, though "cascaded" from your existing modem/router (assuming it has "dynamic IP" as a WAN connection option, I have a TP-Link used that way). It also makes the system "fibre ready" but, of course, uses two devices instead of one.
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Message 9 of 9
(737 Views)
