bbc i player 0x60 on 21cn trial
scootie
any one else getting constant pauses and some times a message saying this content is not working
it's the f1 stream that's playing up other stuff seems o.k all thoe the same did happen one of the others i tested
http://www.bbc.co.uk/iplayer/episode/b00kqt4d/Formula_1_2009_The_Spanish_Grand_Prix_Part_2/
seems throughput on this is running at 0.5mb to 1mb
139 REPLIES 139
scootie
Re: bbc i player problem
correction it happening pretty much on all the programs 0.5 -1mb average.
is this bbc, pn or the 21cn trial at fault?
Fixes: 1,483
I'm watching it fine with no stuttering
Fixes: 1,483
10 minutes in no stuttering. Well apart from Button at the start  Wink
scootie
o.k time to double check my connection before pointing fingers at 21cn Angry
dam you adiwoo no more spolers plz, the news recked the winner for me dont give any more away Angry
Oldjim
Resting Legend
Fixes: 63
No problem here - it is probably all the errors you are getting because your synch speed is too high  Grin Grin
scootie
jealousy dosent suit you o wise wizard
Fixes: 1,483
Quote from: ASBO
you didn't even get that far? shame. I'll try to  Lips_are_sealed
But yeah I'm with our magical friend, drop your connection back a few Mb  Tongue
BTW here are my stats
Connection Speed   6208 kbps   832 kbps
Line Attenuation 50.0 db 27.0 db
Noise Margin 5.0 db 10.0 db
scootie
its not my connection guys.
right bbc iplayer pauses on its own and runs at average 500kbps.
but i can run bbc why it contantly pauses and tvcatchup  that runs streams at 800kbps and tv catch up at same time is fine Crazy
trust the pooch its not errors on his lovely line  Smiley
Today 20:54 3668 kbps (459kB/s) 728 kbps (91kB/s)
scootie
it dosent even attempt to buffer it when i sart it now not a sausage on the thoughput front when i click play Angry
think its time for the 21cn section to get lit up by me yet again
Fixes: 1,483
33 minutes in and still flowing nicely.. do you want an update?
Oldjim
Resting Legend
Fixes: 63
This is what my data rate shows - only iplayer running
scootie
right who is having a complete mick take of the wireshark freak
fancy swaping this thread into 21cn section adi and i will re title it
Fixes: 1,483
[Moderator's note by Adie (Adiewoo) moved as seems related to 21CN trial and as requested OP]
scootie
Re: bbc i player 0x60 on 21cn trial
cheers adiewoo
no wonder latency has been gd  Roll_eyes
