:( bad gaming
- :( bad gaming
- « Previous
- Next »
Re: :( bad gaming
03-10-2012 9:12 PM
The thing is when I disconnect before restarting I still get a drop in sync and speed, so for me to switch to another gateway risks a drop in sync. So I take the risk and swapped earlier which gave me a better gaming experience, then I get auto swapped back onto the bad gateway, where i am stuttering again, and can't hit anything. So what do I do now (stop moaning I here you all say ) wait for three days before I dare swap gateways again ?
Just swapped gateways from ptn-ag03 to ptn-ag01 and guess what, a drop in sync and a drop in speed, this is bull****.
Re: :( bad gaming
03-10-2012 9:55 PM
but come on PN do your usual stuff ,,, get it sorted please
Re: :( bad gaming
03-10-2012 10:44 PM
Im now on this ( You are currently connected to the gateway known as pcl-ag04. )
This is located in City Lifeline House.
When i had the problems i was on pcl-ag02 , tbh i should not have to chase up all this gateway carry on... PN need to fix these issues. ITs really nice here but if these problems carry on then im not staying im moving, i rely on a steady connection to game if this fails and carrys on failing then im out.
Re: :( bad gaming
03-10-2012 11:15 PM
ukste20: Did hopping to pcl-ag04 fix the problems?
ukste20/JamesM: What you've described is really weird. This isn't normal congestion caused by imbalance stuff. We'll have another good look tomorrow
Ex-Broadband Service Manager
Re: :( bad gaming
03-10-2012 11:38 PM
Re: :( bad gaming
04-10-2012 12:16 AM
Kelly it is weird, I can't understand it, I play on the same servers, 64 man seine or Bazaar, and usually only alternate between 3 servers, T.O.G.A, SCAN and Banana Republic, because I get a ping of 16, 11 and 11 respectively. Some nights I can get a 4x K/D ratio and then others I am lucky to break even. I remember a few years back that when gaming I could be on fire until around 10 PM then it just died in the ****. This went on for months in BF2 and BFBC2. Even back then no-one could explain it.
Anyway the gateway hop (or whatever happened) seems to have worked, I will just leave it now.
Re: :( bad gaming
04-10-2012 10:25 PM
Re: :( bad gaming
04-10-2012 10:46 PM
Re: :( bad gaming
05-10-2012 9:26 PM
Re: :( bad gaming
05-10-2012 10:28 PM
Re: :( bad gaming
05-10-2012 10:56 PM
- « Previous
- Next »
