:( bad gaming
rongtw
Fixes: 12
:( bad gaming
am sorry to say i am here again  Embarrassed  just lately while gaming bf3  Wink i have been getting the Red warning triangle , which tell you your connection is bad .
the game becomes unplayable , But i am on fibre 80/20 ?? so why
i haven't got any wiresharks or any captures as it is just the Odd time it happens , tonite between 9pm& 10 pm ,  i used to get it also before i went on fibre i hoped the swap would stop it  Embarrassed
i dont belive its my PC or routers  for some reason maybe PN have got the game priority wrong or something ?
at mo am on  ptw-ag01.after a router reset ,, power off  Smiley  & yes it still happens Sad
or am i just missing something
Fixes: 4
Re: :( bad gaming
Know what IP you are connecting to?  Get us some traceroutes.  Can you wireshark it?  It's busy tonight, but gaming should be fine.
Kelly Dorset
Broadband Service Manager
Re: :( bad gaming
If the server IP isn't Visible via the game
startbar/run
type cmd
in the dos window type netstat -n -b
In that look for established connections for the games exe, that will be the server IP, or if in a MMO that uses multi IP addresses, the server that is hosting the zone you are currently in
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
JamesM
Re: :( bad gaming
You aren't missing anything mate, I am rubberbanding all over the place, no red triangles for me tonight but something isn't right. BF3 is the only game I play at the moment on PC so I can't say whether it is PN or BF3.
Fixes: 4
Re: :( bad gaming
What gateways you guys on? http://usertools.plus.net/@gateway/
Kelly Dorset
rongtw
Fixes: 12
Re: :( bad gaming
@ kelly at the mo i am on ptw-ag01. after i reset the router last night , before that i was on ag07  Wink
rongtw
Fixes: 12
Re: :( bad gaming
i was on a Dutch server first then moved to a UK server
my speedtest graph shows a few dips in speed
Fixes: 4
Re: :( bad gaming
Have either of you managed to wireshark it then you are having poor performance?
Kelly Dorset
rongtw
Fixes: 12
Re: :( bad gaming
sorry Kelly but no  Embarrassed
Fixes: 4
Re: :( bad gaming
Really want to get this all working ok for you guys.  Chris was gaming last night (not BF3) and saw no issues.  We've not heard any complaints from other BF3 gamers though (ukste? how was it?!) so I'm a little at a loss.
I presume it's normally fine, but just gets bad on Monday or Sunday nights?  (or when we had the apple traffic?)  it seems like you only have issues when we are busy.
Kelly Dorset
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: :( bad gaming
Drop me a friend request on Origin, my username is in the BF3 thread in the gaming section. I'll hop on tonight with you and see if I can replicate the same issues.
 Chris Parr
 Plusnet Staff
rongtw
Fixes: 12
Re: :( bad gaming
sry Chris i couldn't find your name ,, i am " Sneeky Old Hen"  Wink
Re: :( bad gaming
@rongtw http://community.plus.net/forum/index.php/topic,1548.0.html
rongtw
Fixes: 12
Re: :( bad gaming
same again tonite  Embarrassed but got a wireshark ,, but i cant upload it here  Sad
Fixes: 4
Re: :( bad gaming
Cool.  we'll arrange to get it from you.  Can you do a reboot of your router and let me know if it improves?  Tell us what gateway you are on now and afterwards.
Kelly Dorset
