awful wireless performance
- awful wireless performance
04-07-2014 11:22 PM
Can I use a different router than the one Plusnet give you? I still have the Sky Hub which gave a brilliant signal in other rooms. Could I use this Hub? If so could someone tell me how to do it. Please.
many thanks in advance
Met
Re: awful wireless performance
05-07-2014 12:54 PM
http://www.plus.net/support/broadband/hardware/broadband-connection-settings.shtml
05-07-2014 1:08 PM
05-07-2014 4:47 PM
One idea you could consider is to switch off the wireless on the Plusnet router and then use the sky hub as a wireless access point by disabling DHCP on the hub, and then wiring it to the Plusnet router.
05-07-2014 4:58 PM
Quote from: DomS Also try setting a different wireless channel on the router - my wireless speeds were terrible until I changed the channel.
Thanks for your reply. How would I change the channel on my router
met
05-07-2014 4:59 PM
Quote from: zZz The Sky SR101 and SR102 hubs are likely to be locked to Sky so won't work with any other ISP.
Thanks for your reply. How would I use the hub as an access point. I am new to this.
met
dick:green Quote fixed.
05-07-2014 5:15 PM
(I've deleted the response I had originally written)
05-07-2014 5:26 PM
Quote from: met
http://www.plus.net/support/broadband/hardware/technicolor-582n-wireless.shtml
Try channel numbers 1, 6 and 11.
05-07-2014 6:21 PM
met
dick:quote
05-07-2014 6:46 PM
07-07-2014 2:28 PM
I was thinking of getting a wifi extender. any makes recommended
thanks
met
