aria.co.uk - Connection Problems
- Re: aria.co.uk - Connection Problems
15-08-2008 10:41 AM
Is anyone else having touble loading aria.co.uk ? I've checked on two PCs and neither can access it. However, according to http://downforeveryoneorjustme.com/ and various proxies, the site is up
Trace below if it helps:
Tracing route to aria.co.uk [80.74.250.130]
over a maximum of 30 hops:
1 2 ms 1 ms 2 ms home [192.168.1.254]
2 17 ms 17 ms 23 ms lo0-plusnet.thn-ag3.plus.net [195.166.128.80]
3 197 ms 68 ms 199 ms vl303.thn-gw2.plus.net [84.92.3.178]
4 22 ms 17 ms 41 ms ldn-b4-link.telia.net [213.248.84.197]
5 23 ms 19 ms 19 ms ldn-bb2-link.telia.net [80.91.250.238]
6 24 ms 17 ms 17 ms ldn-b1-link.telia.net [80.91.248.89]
7 * * * Request timed out.
8 * * * Request timed out. (Continues to 30 hops)
Message 1 of 6
(1,586 Views)
5 REPLIES 5
15-08-2008 10:57 AM
It appears to be a Plusnet problem as I can connect OK using RIN but not using the Plusnet servers
Just ran a tracert from RIN and something is wrong there as well
Quote Tracing route to aria.co.uk [80.74.250.130]
1 43 ms 99 ms 99 ms speedtouch.lan [192.168.1.254]
2 33 ms 33 ms 33 ms 217.47.71.122
3 34 ms 32 ms 32 ms 217.47.71.161
4 33 ms 32 ms 32 ms 217.47.46.174
5 33 ms 33 ms 33 ms 217.41.171.29
6 33 ms 32 ms 32 ms 217.41.171.65
7 41 ms 37 ms 32 ms 217.41.171.74
8 33 ms 33 ms 33 ms 217.41.217.42
9 33 ms 32 ms 32 ms 217.47.159.43
10 33 ms 33 ms 33 ms core2-pos12-3.kingston.ukcore.bt.net [62.6.40.125]
11 34 ms 33 ms 34 ms core2-pos0-0-0-7.ilford.ukcore.bt.net [62.6.204.238]
12 34 ms 34 ms 34 ms transit1-gig11-0-0.ilford.ukcore.bt.net [194.72.20.146]
13 34 ms 33 ms 34 ms t2c1-ge14-0-0.uk-ilf.eu.bt.net [166.49.168.89]
14 35 ms 34 ms 34 ms POS4-0-2.ar6.LON3.gblx.net [64.212.225.13]
15 41 ms 41 ms 40 ms 64.210.15.126
16 41 ms 41 ms 57 ms man2-gw1.talkinternet.co.uk [80.74.248.33]
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21
Message 2 of 6
(642 Views)
15-08-2008 10:58 AM
put the url into konqueror and firefox 3 and had no difficulty at all. expensive ain't they?
Message 3 of 6
(642 Views)
15-08-2008 10:59 AM
A bit wider than Plusnet. I can't get there from work which is a University of Liverpool connection.
Phil
Edit: Just done a tracert and it is being routed over telia.net, which is one of the same peers Plusnet use, and hence the same point of failure.
Phil
Message 4 of 6
(642 Views)
15-08-2008 11:14 AM
Unusual - I can view the site ( with IE ), but tracert times out. Most strange ....
Message 5 of 6
(642 Views)
16-08-2008 12:05 AM
Works for me
puddy
ps running vista
puddy
ps running vista
Message 6 of 6
(642 Views)
