are upload speeds capped
hooverman
I currently get between 330kbps  and 350kbps  upload speed  ,but when on aol llu I was getting between 600 and 700 kbps, Im now using googles music manager ,I understand I will not get the upload speeds of fibre but a slight increase in speed would be appreciated .
Fixes: 52
Re: are upload speeds capped
Are you on a 21CN or 20CN service? On 21CN Plusnet will uncap your upstream on request. This is free but if you are on 20CN Max Premium which increases upstream sync speed to up to 832kbps costs £7.83 per month.
David
hooverman
thanks spraxyt  for your reply I belive im on 21cn  network so I will probabily raise a ticket to ask
Hi hooverman,
As you're on 21CN I've placed an order to uncap your upload speed, this will complete tomorrow for you and you'll see that your upload speed roughly doubles.
Chris
hooverman
thanks chris  I assume ref spraxyt  that no extra charge is made as Im on 21cn,
That's right, no charge....all free  Grin
