anyone help have to keep clicking connect HELP PLEASE
- anyone help have to keep clicking connect HELP PLE...
08-06-2011 4:57 PM
Re: anyone help have to keep clicking connect HELP PLEASE
08-06-2011 11:14 PM
10-06-2011 1:36 PM
so now any recommendations for a replacement router please
10-06-2011 2:40 PM
In desperation I changed it from using PPPoA to PPPoE (Even though that's the 'wrong' setting) and it cured the disconnections.
Might be worth a go.
10-06-2011 2:57 PM
11-06-2011 8:52 AM
About 2/3 down the page it shows where to set Encapsulation to PPPoA.
Try setting it to PPPoE instead.
I don't know if it will work for you but it did for me so could be worth a go.
11-06-2011 4:55 PM
As this sounds like a router problem, you could try a different router, or ask Plusnet to send you a free one (if you stay 12 months and pay £4.99 p&p)
11-06-2011 5:18 PM
11-06-2011 5:22 PM
15-06-2011 11:36 PM
Did switching from pppoA to pppoE help at all? or did you get a new router?
15-06-2011 11:58 PM
16-06-2011 10:11 AM
16-06-2011 1:34 PM
Interleaving will not show if it's set to fast. Yours however will have been set to Auto, but in the off state. As it's in auto state that's why it will automatically change once an intermittent fault is raised.
Jojo
