any admin on ?
- any admin on ?
- « Previous
- Next »
Re: any admin on ?
03-12-2010 5:35 PM
HI snipperuk,
Been a slight increase to 1500 which I've matched at our end now so if you reboot via the router interface you should see this.
Jojo
Jojo
Message 46 of 48
(139 Views)
Re: any admin on ?
03-12-2010 6:40 PM
still working at this time on a friday
just done a BT test ..... line ip still 350
Download speedachieved during the test was - 253 Kbps
For your connection, the acceptable range of speeds is 50-500 Kbps.
Additional Information:
Your DSL Connection Rate :1504 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 350 Kbps
i'll hang in there till BT have changed my master socket (hopefully)
snipper
snipper
Message 47 of 48
(139 Views)
Re: any admin on ?
17-12-2010 6:48 PM
just an update jojo
had an engineer out .... fitted a new master socket and tested my line and it was syncin at 960kbps and no errors BUT
BT where in the process of replacing some underground cables right next to the exchange(due to degrading) and should be done by this weekend
so hopefully after the weekend i should be back upto 2mb
if not i'll be back
if not i'll be back
Message 48 of 48
(139 Views)
- « Previous
- Next »
