akamai speed cap lower than normal?
Trying to get nvidia drivers and download speed is capping to maximum of 30kB/s and usually stalling.  I have tried with Opera/Waterfox with no change and wireshark shows its on the correct Traffic Priority of 0x80
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
elfish
Re: akamai speed cap lower than normal?
I am also having this issue.
Nvidia drivers and Adobe software.
Addresses that seem to be giving slow dl speeds:
uk.downlaod.nvidia.com
us.download.nvidia.com
ardownload.adobe.com
mherbert
Major speed issues downloading on PS3, router logs show
zeus.dl.playstation.net
which resolves to Akamai IP addresses
Fixes: 190
We're looking into this to see if we can shed any light on it.
[EDIT]
We've raised this internally on Ref: 86019
 Matthew Wheeler
elfish
Thanks Matt.
It also seems to be affecting windows updates (those that are on Akamai servers).
shaunfriend
I can confirm I am seeing the same behaviour on a fibre connection from Plusnet. Feels like very aggressive traffic shaping as it starts out (albeit very briefly) quickly and then very rapidly reduces down to 0bytes/s
elfish
If its any help, I can stream HD video via BBC iPlayer without issue from the Akamai servers.
no url's supplied for others to test.
I just tried http://uk.download.nvidia.com/Windows/350.12/350.12-desktop-win8-win7-winvista-64bit-international-w...
It is crawling at a very low speed.
I am on a unlimited product so why am I rate limited?
downloading via a proxy gives a speed about 90% of line speed.
oh dear.
NoZephy
Having the same problems with Nvidia's downloads, stays around 15-30kb/s and then stalls completely. I also noticed that Malwarebytes took unusually long to update as well.
Hopefully this gets sorted quickly.
mherbert
Thanks Matthew.
It's taking *days* to download DLC from Playstation Network (Akamai IP addresses)
Fixes: 162
We'll post back when we've got any update on the problem.
 Chris Parr
 Plusnet Staff
the problem still exists now incase you wasnt aware, so seems it has no relation to peak time.
Fixes: 162
Thanks all, any chance of a couple of tracerts from someone who is affected?
 Chris Parr
 Plusnet Staff
http://uk.download.nvidia.com/Windows/350.12/350.12-desktop-win8-win7-winvista-64bit-international-w... gives the attached trace, no change today still can't download it
edit: due to get fibre tomorrow to complicate things, if trying to do a remote test with my connection
Tracing route to a453.d.akamai.net [23.192.162.98]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  home.gateway [192.168.1.253]
  2    42 ms    17 ms    16 ms  lo0-central10.pcl-ag08.plus.net [195.166.128.189
  3    16 ms    15 ms    15 ms  link-a-central10.pcl-gw01.plus.net [212.159.2.18
8]
  4    16 ms    19 ms    15 ms  xe-9-1-0.pcl-cr01.plus.net [212.159.0.220]
  5    16 ms    15 ms    16 ms  ae1.ptw-cr01.plus.net [195.166.129.0]
  6    16 ms    16 ms    18 ms  ae2.ptw-cr02.plus.net [195.166.129.5]
  7    *        *        *    Request timed out.
  8    20 ms    20 ms    20 ms  a23-192-162-98.deploy.static.akamaitechnologies.
com [23.192.162.98]
