adsl2+ and RWIN
- Re: adsl2+ and RWIN
adsl2+ and RWIN
02-06-2010 9:37 PM
Currently my connection synch is 8128/448 with an IP of 7150. 6-years ago, I set the RWIN based on the formula :-
RWIN = 8 x N x (MTU - 40), using an MTU of 1500, with XP.
Where N = whole No and "8" is Connection Rate to nearest Mbps.
The formula from the Plusnet site.
I will shortly be connected to the 20Mbps service and wondered how this formula should be adapted. Should "8" be replaced with "20" or by the actual download speed to nearest Mbps?
I have received info from Plusnet that suggests the latter, viz "12" if actual download speed is 12,000kbps, which doesn't reconcile with the original formula. Perhaps I did not make my query clear.
Can anyone offer me guidance?
Regards
Regards
Message 1 of 7
(1,397 Views)
6 REPLIES 6
Re: adsl2+ and RWIN
02-06-2010 10:08 PM
Yes, increase RWIN linearly according to connection speed.
I'm on ADSL2+ running at around 20mbps. My RWIN is 528000 though I can't recall exactly what value of N I used.
Message 2 of 7
(526 Views)
Re: adsl2+ and RWIN
02-06-2010 10:21 PM
Many thanks HPsauce.
Do you mean increase RWIN proportionately? I would have thought the MTU remains the same.
Do you actually get 20Mbps download speed? Or is that your Synch speed?
Using Kitz's "Max dsl Speed Calculator," my estimated likely connection will be a Synch of 17,056kbps and IP Profile of 15,000kbps
Regards.....
Regards.....
Message 3 of 7
(526 Views)
Re: adsl2+ and RWIN
02-06-2010 10:49 PM
Quote from: fotobits Do you mean increase RWIN proportionately?
Yes.
Message 4 of 7
(526 Views)
Re: adsl2+ and RWIN
05-06-2010 7:33 PM
Apparently Win 7 does it http://www.sevenforums.com/network-sharing/11145-rwin-tweaking.html autom atically.
Message 5 of 7
(526 Views)
Re: adsl2+ and RWIN
05-06-2010 9:12 PM
@lucerne. so does vista
Message 6 of 7
(526 Views)
Re: adsl2+ and RWIN
05-06-2010 9:18 PM
So does Linux.
Message 7 of 7
(526 Views)
