adsl stats from my billion seem a little odd
- Re: adsl stats from my billion seem a little odd
22-05-2016 8:09 PM
I have a billion 7800n, these are my adsl info --show results
Login: admin
Password:
> adsl info --show
adsl: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 13203 Kbps, Downstream rate = 3256 Kbps
Path: 0, Upstream rate = 440 Kbps, Downstream rate = 2450 Kbps
Link Power State: L0
Mode: ADSL2+
TPS-TC: ATM Mode
Trellis: U:OFF /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 4.7 9.2
Attn(dB): 67.0 37.7
Pwr(dBm): 17.3 11.8
ADSL2 framing
MSGc: 59 44
B: 76 22
M: 2 4
T: 1 1
R: 12 12
S: 1.9850 6.4000
L: 669 130
😧 16 1
Counters
SF: 10164045 646806
SFErr: 256238 57
RS: 330331474 3672674
RSCorr: 119189417 213
RSUnCorr: 478598 0
HEC: 142651 24
OCD: 47 0
LCD: 0 0
Total Cells: 947090534 170115214
Data Cells: 66333600 6427902
Drop Cells: 0
Bit Errors: 0 2855
ES: 111724 44
SES: 9 0
UAS: 18 18
AS: 163933
INP: 1.14 0.36
PER: 16.12 20.00
delay: 7.94 1.60
OR: 32.24 20.00
Bitswap: 516 22
it's the upstream speeds that confuse me, am I missing something?
23-05-2016 8:50 AM
I had a Billion 7800N a couple of years ago, then on a long line just like yours.
I used to see the same behaviour with it re the max upstream figure; 15428 and with an actual upstream rate of 686. It appears to be an oddity with the 7800, but I have also seen it, very rarely, on certain other routers, eg a DG834GT.
I don't think its anything to be worried about.
23-05-2016 8:56 AM
Looks like your upstream is capped and you could gain a bit by having it uncapped.
