adsl router syncing problems
- adsl router syncing problems
- « Previous
- Next »
Re: adsl router syncing problems
23-09-2007 6:35 PM
the same problem is occuring again. The noise margin has shot back up to 11db and the sync speed has dropped again back to 4096kbps. I am still connected to the master socket. Previously since last week my line has been syncing at 7800kbps. The Line Attenuation which is at 22db indicates that it can certinly handle 8meg whcih it has been up till now.
23-09-2007 6:39 PM
23-09-2007 7:15 PM
While you may have had the SNR reduced, this does not stop the system going through the same process it did before should it detect what it believes to be a bad line. There is nothing PN can do to stop this happening, its just one of the failings with the BT method of ADSL supply.
24-09-2007 9:07 AM
James was dealing with the problem, and he requested BT to reduce the noise margin down to 6db. This change was made, then for some reason was changed back. If you check out my ticket which i closed, you will be able to see the progress made by James.
24-09-2007 9:12 AM
There has to be a fundamental reason for your SNR changing again. Did you change your telephone socket again? If not, the problem may be more widespread than initially expected.
24-09-2007 9:23 AM
i have not changed a thing on my line or on my netgear adsl router.
24-09-2007 10:23 AM
I'll have a look and see if I can find anything out.
24-09-2007 10:53 AM
I'll let you know as soon as I hear back.
24-09-2007 6:26 PM
28-09-2007 5:25 PM
I'm not sure if this is a coincidence but on the 25/7/07 tiscili LLU was enabled at my exchange, after which all these syncing problems have been occuring. I also hear that plusnet are using the tiscili llu. Could this be the problem?
One of the bt engineers rang me the other day saying that he was checking the exchange, up to now i havn't heard anything.
28-09-2007 5:48 PM
- « Previous
- Next »
