adsl modem and vista
- Re: Wireless Router
21-08-2007 2:25 PM
My pc is on its last legs and is to be replaced soon. Plus net support tell me that the adsl modem that came from them when I joined up will not be suitable for a Vista pc - any idea why?
Message 1 of 9
(3,143 Views)
8 REPLIES 8
Re: adsl modem and vista
21-08-2007 2:28 PM
If it's the USB Voyager 105 then it's because this modem has been discontinued by BT and they haven't created the vista drivers for it.
AFAIK the only USB modem that has vista drivers is the speedtouch 330. You would probably be better off with a router as these are not operating system specific.
Message 2 of 9
(783 Views)
21-08-2007 3:13 PM
no it's not a Voyager 105, can't remember the name just now - it's a small rectangular dark blue box, with a light blue usb cable out of one end, rj cable goes in the other end and two small green leds if that helps ... I'll check tonight.
Message 3 of 9
(783 Views)
21-08-2007 3:17 PM
It's not a Speedtouch either unfortnately. Sounds like the perfect opportunity to upgrade to a router!
Message 4 of 9
(783 Views)
Re: Wireless Router
21-08-2007 4:40 PM
it's a Zyxel Prestige 630S USB Modem.
Message 5 of 9
(783 Views)
Re: Wireless Router
21-08-2007 4:45 PM
Quote from: normd it's a Zyxel Prestige 630S USB Modem.
We no longer supply the Zyxel Prestige, all the kit available via BBYW products is BT Voyager kit, the model depends on which option you choose.
Message 6 of 9
(784 Views)
21-08-2007 4:50 PM
I believe this post was intended for this thread, so I have moved it across for you.
Jonathan
aka Chilly
Message 7 of 9
(784 Views)
22-08-2007 9:43 AM
any router recomendations then? Old PC has thoroughly hacked me off now and am getting grief from the kids. Current thoughts are to go and get a complete package from Tesco and a wireless router from Currys on the way home tonight - good idea? bad idea?
Message 8 of 9
(784 Views)
22-08-2007 12:55 PM
the Linksys WAG54G Series of routers are my choice, never had a problem with them.
Message 9 of 9
(784 Views)
