adsl 1 or adsl 2
- adsl 1 or adsl 2
Re: adsl 1 or adsl 2
13-11-2014 2:03 PM
13-11-2014 2:17 PM
The reason for the questions about the Sky box is because some sky boxes (usually older ones) have power supplies that start failing and giving out lots of interference that affects broadband, so that's something we want to keep an eye on.
Can you post another lot of TG582n Full DSL stats now so we can see how the errors are changing, and also some more this evening sometime. I'll also explain a bit about how your speeds can be affected by things like your current IP Profile this evening.
Whilst you are logged into the TG582n getting the stats, can you click on <Technicolor Gateway> on the left hand menu, and tell me what it says for Software Release towards the centre of the screen. Don't post the serial number.
13-11-2014 2:46 PM
DSL Connection
Link Information
Uptime: 0 days, 5:04:33
DSL Type: ITU-T G.992.3
Bandwidth (Up/Down) [kbps/kbps]: 440 / 3.872
Data Transferred (Sent/Received) [MB/MB]: 52,95 / 274,98
Output Power (Up/Down) [dBm]: 12,6 / 0,0
Line Attenuation (Up/Down) [dB]: 32,2 / 55,5
SN Margin (Up/Down) [dB]: 18,8 / 6,4
Loss of Framing (Local/Remote): 18 / 0
Loss of Signal (Local/Remote): 2 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 96 / 0
FEC Errors (Up/Down): 362 / 689.159
CRC Errors (Up/Down): 0 / 2.343
HEC Errors (Up/Down): 0 / 102.182
13-11-2014 2:49 PM
Technicolor Gateway
Information
Product Name: TG582n
Serial Number: xxxxxxxxxxx
Software Release: 8.4.4.J
13-11-2014 2:54 PM
Those errors are not good, quite an increase in the last 2 hours.
Edit: sorry NOT good, just edited on spotting mistake.
13-11-2014 2:57 PM
13-11-2014 3:00 PM
13-11-2014 3:05 PM
13-11-2014 3:06 PM
13-11-2014 3:09 PM
13-11-2014 3:13 PM
I think with the upgraded firmware pushed, that will certainly help - you'll have to set up your wireless connection afresh when it's done, it certainly won't make matters worse and should improve things.
Post back some more stats this evening then pegasus20 and we'll see how things are going.
13-11-2014 3:16 PM
13-11-2014 3:23 PM
13-11-2014 3:24 PM
13-11-2014 5:32 PM
DSL Connection
Link Information
Uptime: 0 days, 0:24:59
Bandwidth (Up/Down) [kbps/kbps]: 440 / 2.905
Data Transferred (Sent/Received) [MB/MB]: 67,07 / 317,77
Output Power (Up/Down) [dBm]: 12,8 / 0,0
Line Attenuation (Up/Down) [dB]: 32,2 / 54,0
SN Margin (Up/Down) [dB]: 16,3 / 13,9
Error Seconds (Local/Remote): 157 / 0
FEC Errors (Up/Down): 33 / 54.001
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
