admin Please can you
- admin Please can you
23-07-2010 5:31 PM
i while back in april PN Ramidoodle tweaked my snr at your end and fixed it at 6db max to give me better speeds
this seems to has been reset ?
can this be capped again Please
many thanks
many thanks
Message 1 of 8
(1,276 Views)
7 REPLIES 7
Re: admin Please can you
26-07-2010 10:56 AM
If it has been reset then the line can't support 6dB.
We are happy to tweak target SNR margins but unfortunately we can't keep going back to perform the same changes on lines that can't support it.
However, you might be interested to use something like DMT Tool and take a look at Oldjim's posts on this thread for some real-life information about using DMT Tool to force SNR margin.
Message 2 of 8
(615 Views)
26-07-2010 6:52 PM
all very well if your a techy
first reset i had was through a thunderstorm
and the latest was due to installing a near router
Message 3 of 8
(615 Views)
26-07-2010 7:50 PM
Quote from: snipperuk and the latest was due to installing a near router
"Near router" meaning what??? Or is that a typo for Netgear router?
Message 4 of 8
(615 Views)
27-07-2010 10:03 AM
If it was a temporary issue that caused your target SNR margin to increase then it will decrease in time, assuming the line can support it.
Message 5 of 8
(615 Views)
29-07-2010 8:19 PM
ive just used the dmt tool with help from old jim ....... 71hrs with no issuse's yet
Message 6 of 8
(615 Views)
30-07-2010 10:16 AM
Excellent, what did you reduce it to? What was the effect on your sync speeds?
Message 7 of 8
(615 Views)
30-07-2010 10:34 PM
hi ben
capped it at 6db but has been 5.4 to 4 at a sync of 2368
97hrs with no problems yet .... line attenuation is 63.5 so a through put speed of 2mb is good for where i am
Message 8 of 8
(615 Views)
