accessing spam folder without webmail
- accessing spam folder without webmail
11-09-2007 3:17 AM
I find the spam filter works fine but it keeps producing the odd false positive from certain senders despite my attempts to train it. This means I have to keep checking my spam folder through webmail just to make sure there isn't something waiting there which is a pain because I prefer my software and I'd rather not log on to my several mailboxes just to check. One solution is to use IMAP to check the spam folder, which again messes up my setup. Is there some software that will allow me to check only the spam folders of several mailboxes periodically? An idea would be PN to add the option to forward spam to another address (eg spam@ or blackhole@), instead of us having to choose between the respective spam folder or the inbox. This way the spam mailbox can be checked independently.
Message 1 of 4
(1,254 Views)
3 REPLIES 3
Re: accessing spam folder without webmail
11-09-2007 8:08 AM
I use Outlook as my main mail client. I also use Thunderbird in IMAP mode to monitor the spam folders. You just need to go in to the properties of the spam folder and set "Check this folder for new messages" - works a treat for me.
Message 2 of 4
(494 Views)
11-09-2007 9:04 AM
Most email clients allow you to create a new account / user which you can then setup in IMAP mode to view your spam folder without affecting your existing accounts.
I use OE and have setup several additional accounts to check the spam folder from a number of mailboxes I have. I can then easily move false positives to my main accounts within OE.
Message 3 of 4
(494 Views)
11-09-2007 9:11 AM
I don't have an Outlook account pointing at my catchall mailbox. When I find an email in there I can move it from that mailbox to a mailbox that is collected by my email client using Thunderbird - you can't move messages between accounts in webmail!
Message 4 of 4
(494 Views)
