accessing my router to change password
duncan6
Can anyone help me, I know its probably very basic but I need to change the password on my router and can not remember how to do it
Help please
6 REPLIES 6
Fixes: 334
Re: accessing my router to change password
Which Hub and which password, @duncan6 ?
duncan6
it is the Hub one, I have all the passwords
Fixes: 334
OK, it is a Hub1. Which password do you wish to change?
duncan6
OK I have managed now
bobpullen
Fixes: 327
Welcome to the forums.
Which password are you referring to and what router are you using?
Broadband password - e.g. the password that your router uses to physically establish a connection to the Internet. In most circumstances, you do not need to manually update this password as it happens automatically whenever your account password via the Plusnet website.
Router admin password - This is the password used to log into your router configuration pages. What it is, how you change it and what address you need to browse to to get to it all depends on the router you're using. Most Plusnet-provided routers use http://192.168.1.254
Wi-Fi password - This is the password your devices use to connect wirelessly to your router. Depends again on what router you're using but can be changed via the router configuration pages.
Edit: everybody else beat me to it Wink
chips
Slightly different.  BT6 router not automatically updating. When I try to change password a "helpful" note tells me "BT customers don;t need this" - but I am not a BT customer.  I have entered admin password but cannot edit password. Do I need to reset the router or somesuch ?  Each time I log on I have to run troubleshooter which "resets adptor options" and all is well but it is tedious.
