access to www,adobe.com
- access to www,adobe.com
- « Previous
- 1
- 2
- Next »
Re: access to www,adobe.com
24-08-2008 11:28 PM
I've had a fault logged with plusnet support for a few days and have been going through the same process.
Initially thought it was DNS problem, main page loads when I use IP address rather than URL but can't navigate anywhere else on site.
Can Ping and Tracert to adobe.com OK but can't access it using any of 4 machines (XP and Vista) using several web browsers (IE7, safari, opera).
All machines are fine using USB 3G modem so problem is either router or broadband connection
As part of diagnostic I'll be trying USB broadband modem tomorrow. If that works, I'll try full hardware reset on the router.
25-08-2008 11:00 AM
25-08-2008 12:50 PM
Thanks for all your help.
Regards,
Photoart
27-08-2008 9:57 AM
I'm going to try lowering the MTU as it is the one thing others have suggested that I haven't tried
Just out of interest, have you noticed a drop in broadband line speed ?
My connection used to run at over 3000kbps but I'm currently only getting about 1800kbps - I've got plusnet looking into it and had assumed it was unrelated to the adobe website issue but you never know.
Once I confirmed that I could access adobe.com using usb modem but not with router plusnet support seemed to lose interest. Is everyone with a BT voyager 2100 unable to access adobe ? If not, it could still be a issue with their infrastructure that only effects the 2100
27-08-2008 11:22 AM
29-08-2008 3:48 PM
All of a sudden I could browse to adobe.com - I then checked the other laptop that I had made no MTU adjustments to and that could also access adobe.com
I managed to load the updated Reader on both machines, but then I tried a 3rd machine (desktop) it could not see adobe.com
Went back to the laptops and neither of them could connect to adobe.com
It is interesting that the brief adobe.com access happened during a period when my broadband line was being reset to try to fix a connection speed problem.
Connection speed issue still not resolved, still wondering if the two issues are connected ?
31-08-2008 1:05 AM
01-09-2008 9:40 AM
I also have not been able to access www.adobe.com and I have a Bt Voyager 2100.
All other web sites are fine.
04-09-2008 6:05 PM
Quote from: MickKi From what you're saying the access to adobe is intermittent, which may make it more difficult to troublshoot. If one can access a website using the IP address, but not the FQDN then the problem is with the DNS part of the equation. You may want to try setting the secondary DNS address on your router to opendns: https://www.opendns.com/start
If I had a pound for everytime I have reconfigured router / computer DNS settings, DHCP IP range and sub-net mask I'd certainly have bought a new 802.11n router with the money 🙂
My line speed issue is fixed, still can't connect to www.adobe.com
I got a reply from the BT Voyager support people which basically said "old product, you're on your own - unless you'd like to sign up for our very reasonable technical support service" and even then they'd probably still suggest changing the router.
I have no idea what I did to get it briefly working - haven't been able to since that one occasion,
04-09-2008 6:19 PM
05-09-2008 8:13 AM
- « Previous
- 1
- 2
- Next »
