a newbie bt hub router v plus net router?
- Re: a newbie bt hub router v plus net route...
19-05-2012 10:40 AM
hiya next week i go live ,but just wanted to ask something plzzzzzz..
ok then,,,,, plus net will send me a new wireless router,,,,
at the moment i have a older ,bt hub router ver 2. ( came with a small phone)...
do you think ,IT IS best to use the NEW router .?
as the other is older now
Message 1 of 6
(1,550 Views)
5 REPLIES 5
Re: a newbie bt hub router v plus net router?
19-05-2012 12:05 PM
It was a bit hard working out what your trying to say from your post dude.. I suspect thats why no ones replied.
Id say use the PN provided one at first for the 10 day training period, and then compare the two (Look at noise margins etc, and sync speed most importantly).
Whichever one has the higest sync (and is the most stable) is the one you should go for.
Message 2 of 6
(491 Views)
19-05-2012 12:27 PM
hiya thats exactly what i needed to know..
with regret im not too clever , and never new about syng speeds..
all i can say ny bt was quite fast up to 6mbs,
from what you say then ,, i will plug in the new PN ROUTER..
Message 3 of 6
(491 Views)
21-05-2012 10:19 AM
Hope it all works well for you, please let us know how it goes. Also, thanks for choosing us and welcome to the forums
Message 4 of 6
(491 Views)
21-05-2012 10:26 AM
Quote from: kdoug007 bt hub router ver 2. ( came with a small phone)...
As far as I am aware, The hub phone will not work on plusnet so I would just stick with the plusnet router.
Message 5 of 6
(491 Views)
21-05-2012 10:50 AM
hiya .. 1st of course your correct , the hub phone would not work..
but it SHOULD STILL WORK , I WOULD HAVE THOUGHT ,only with my land line phone number,,,,
as when my other land line rings,, the hub phone does also..
as there linked together
Message 6 of 6
(491 Views)
