Zero upload speed
- Zero upload speed
Zero upload speed
30-10-2015 3:08 PM
Can this be looked at please?
This is with na wired connection.
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
Download Speed
8.36 Mbps
0 Mbps 21 Mbps
Max Achievable Speed
Download speedachieved during the test was - 8.36 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 8.72 Mbps
Upload Speed
0.14 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.14Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Re: Zero upload speed
30-10-2015 3:10 PM
30-10-2015 3:26 PM
I am using a BT HHub4. Using PP hub makes no difference.
30-10-2015 10:42 PM
31-10-2015 8:35 AM
Stats.
DSL Connection
Link Information
Uptime: 0 days, 1:04:58
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 888 / 10,135
Data Transferred (Sent/Received) [MB/MB]: 17.19 / 230.53
Output Power (Up/Down) [dBm]: 12.4 / 0.0
Line Attenuation (Up/Down) [dB]: 18.8 / 34.0
SN Margin (Up/Down) [dB]: 13.1 / 5.8
Loss of Link (Remote): -
Error Seconds (Local/Remote): 5 / 0
FEC Errors (Up/Down): 33 / 39,095
CRC Errors (Up/Down): 0 / 8
HEC Errors (Up/Down): 0 / 92
Internet keeps dropping.
Internet
Connection Information
Link Status: IPv4 connected
IPv6 disconnected
Uptime: 0 days, 0:12:31
Data Transferred (Sent/Received) [MB/MB]: 15.01 / 203.63
31-10-2015 2:13 PM
Not sure I'll be stopping another 12mnths fed up with PN
31-10-2015 3:00 PM
or in your cabinet - fibre installs etc.
31-10-2015 3:56 PM
02-11-2015 9:58 AM
Quote from: HaresEar Had a line reset and things got worse. line S/N now 15/9db pants.
Your comments on the ticket are that the line is more stable now, is that not the case?
If it is more stable at the higher SNR then something is causing noise/errors which means at the moment we shouldn't put you back on 6db.
Is there any noise on the phone line? Plug a handset in to the master socket and dial 17070.
27-11-2015 7:32 PM
I have had more than my fair share of line faults and I suspect this is down to poor network investment from listening to previous engineer visits.
Link Information
Uptime: 0 days, 1:09:16
Bandwidth (Up/Down) [kbps/kbps]: 1,215 / 10,724
Data Transferred (Sent/Received) [MB/GB]: 590.92 / 8.03
Output Power (Up/Down) [dBm]: 12.1 / 0.0
Line Attenuation (Up/Down) [dB]: 18.7 / 33.5
SN Margin (Up/Down) [dB]: 6.0 / 5.8
Loss of Framing (Local/Remote): 111 / 0
Loss of Signal (Local/Remote): 14 / 0
Error Seconds (Local/Remote): 16,228 / 1
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 4 / 54
HEC Errors (Up/Down): 2 / 112
01-12-2015 4:21 PM
Awaiting PP response. Speed dropped and upload speed very poor again. I am not very happy and have been loyal to Plusnet so far!!!!
02-12-2015 12:11 PM
03-12-2015 1:47 PM
Link Information
Uptime: 1 day, 19:19:54
Bandwidth (Up/Down) [kbps/kbps]: 1,155 / 9,619
Data Transferred (Sent/Received) [MB/GB]: 319.69 / 5.53
Output Power (Up/Down) [dBm]: 12.2 / 0.0
SN Margin (Up/Down) [dB]: 6.1 / 6.6
Error Seconds (Local/Remote): 26,936 / 0
CRC Errors (Up/Down): 203 / 417,252
HEC Errors (Up/Down): 163 / 86,698
