Youtube steaming/buffering problem
- Youtube steaming/buffering problem
08-08-2012 7:49 AM
Ideas/pointers?
Re: Youtube steaming/buffering problem
08-08-2012 11:39 AM
08-08-2012 1:29 PM
08-08-2012 1:50 PM
Quote from: anything .... its only yt giving me problems?
Pardon?
08-08-2012 1:55 PM
It is possible that there is a traffic classification problem.
Can you see what Wireshark shows http://community.plus.net/library/faults/using-wireshark-for-data-capture/
08-08-2012 2:00 PM
On the basis that the problem is confined to YouTube then it could not have been your browsers or Flash either. But then if it was some issue with Plusnet's network then we would all be experiencing the same problems.
Could it be your router playing up? I have seen slowness on certain sites disappear when the router is changed. Bad router settings on a good router can do this too.
08-08-2012 9:04 PM
Well,just had a look and tried to read the log here,seems that every packet comes back as 0X00 ...Differentiated Services Field: 0x00 (DSCP 0x00: Default; ECN: 0x00: Not-ECT (Not ECN-Capable Transport)).
Might be doing/reading it wrong tho.
08-08-2012 9:42 PM
Can you print it to a pdf and post that
08-08-2012 10:22 PM
08-08-2012 10:47 PM
Hopefully a rep will pick this up in the morning
09-08-2012 10:03 AM
Quote from: anything All seems good after switching back to PN,but YT doesn`t stream,keeps buffering. Tried different browsers,updated flash all with no change. Previous LLU isp and when i was on PN before that on 20CN,YT was fine,but PN 21CN gives me the "buffers" so to speak. Other sites stream video fine tho.
Ideas/pointers?
Are you sure you're connected via your Plusnet connection? If so, is it the account associated with your Community Site username or a different one? I've checked the connection logs for the account associated with your Community Site username and there's only a single session from the 27th July that lasted seconds?
If you're connected via another account then are you using a VPN or something similar? I notice the IP you're posting from is not a Plusnet IP address although I guess you could be posting from work?
I've looked at the capture you've provided and it doesn't look like the YouTube traffic is being ToS marked at all and I'm pretty sure you're not bypassing our traffic management switches completely
09-08-2012 11:26 AM
09-08-2012 11:31 AM
Ex-Broadband Service Manager
09-08-2012 12:58 PM
O-Bit Telecom Limited
09-08-2012 12:59 PM
The IP I posted from last night, was it 77........?
....o-bit? That's them, strange.
