Youtube problems
- Youtube problems
Re: Youtube problems
18-06-2013 3:12 PM
18-06-2013 3:21 PM
Unfortunately my speed seems to be all over the place as I'm still in training, I just got a 40Mbits result o_O
Might be worth testing other sites to see if it's not just a peering issue with google. I've also noticed BBC iPlayer cutting out a lot too. Moreso than when I was Be last week.
Is the the infamous afternoon congestion I keep hearing about?
EDIT: Does PN peer with google and/or the BBC?
EDIT2: Quick Google found this page ( http://www.plus.net/features/network/technical_info.shtml ) which shows PN peer with the BBC, but only at 1Gbps. But would that still cause issues at times I'm seeing, even at 2am at night?
18-06-2013 3:58 PM
http://bgp.he.net/AS6871#_peers
18-06-2013 4:02 PM
I've watched bbc iplayer in HD for an hour earlier and that was fine here, lovefilm also appears to be ok.
18-06-2013 4:23 PM
18-06-2013 5:48 PM
18-06-2013 6:20 PM
uninstall FF 21 cleaned then fresh install , But it still happens
19-06-2013 12:31 PM
Just hope that normal service will resume soon after their "tweaking".
19-06-2013 12:53 PM
19-06-2013 12:54 PM
05-10-2013 1:52 PM
youtube sometimes will not start, and half way in to the video it stops and will not buffer
same with steam, it puts me as off line for a min or so, even though I never drop vdsl sync and google still works at the time
with downloads and video streaming my download meter shows cut-outs every few seconds, 55Mbps, then 0Mbps, then 55 again
this is on all pc's and I only use cat6
was not like this for the first few days of vdsl and never like it on adsl2+ adsl1
is this a pn only problem? I asked friends in the us and uk to play the videos and they had no problem
05-10-2013 2:09 PM
05-10-2013 8:44 PM
06-10-2013 1:49 AM
just so it will play without buffering.
06-10-2013 1:43 PM
Quote from: Spiritual Ive been having problems with online video since I change to Plusnet. Its a pain in the "£$%, when on a 60Mb/20Mb connection, you can see youtube dropping the quality from 1080p to 360p,
If you have win 7 can you run network meter gadget and see if you get cut outs
http://addgadgets.com/download/Network_Meter.zip
with my other isp I had problems with speed on adsl1 20cn networks (Hot vp 20cn), but not cut-outs every few seconds,
the meters I used with them have always been a steady line for the most part, but never cut outs like all, nothing, all. and this is not the exchange dropping sync as its up all the time
this is with steam too, its like pn is cutting off for a few seconds as steam puts me as off line even though I can google at the time
