Your current broadband speed is 6500 Kbps
- Your current broadband speed is 6500 Kbps
07-11-2007 8:31 AM
The PlusNet page is showing that my current broadband speed is 6500 Kbps. However my router is showing a constant 8128 kbps. Whilst I would expect there to be a difference between the two, I am surprised that it is such a large one. Can someone please advise me if this is normal or should I be receiving a higher rate from the PlusNet page?
Message 1 of 3
(1,499 Views)
2 REPLIES 2
Re: Your current broadband speed is 6500 Kbps
07-11-2007 8:47 AM
If you have a look at this page it shows you what profiles you should expect against which stable speeds. If you maintain that sync rate, your PlusNet profile will rise to 7000Kbps.
Message 2 of 3
(397 Views)
07-11-2007 8:53 AM
Thank you James.
Message 3 of 3
(397 Views)
