You are currently connected to the "unknown" gateway.
rachaelov
On the which gateway tool: what does this mean? I'm currently experiencing low download speeds, I wonder if this is related?
Re: You are currently connected to the "unknown" gateway.
Check out this thread:
Unknown gateway
I'm on it at the moment and speeds are as normal.
rachaelov
Cheers there - so perhaps interestingly quirky, but not necessarily a problem. Well, back to the drawing board regards speed. I'll keep an eye on that thread tho just in case I can glean something.
