Yikes: Just been connected at new address and...
- Yikes: Just been connected at new address and...
26-11-2009 4:42 PM
Over the last half an hour my noise margin has risen to 21 from about 4. you can imagine the steep graph that gives on Router Stats !!
Current router stats (DG834gt with DG Team software):
ADSL Link Downstream Upstream
Connection Speed 416 kbps 448 kbps
Line Attenuation 61.0 db 31.5 db
Noise Margin 22.6 db 14.0 db
Several dropped connections over this time. Speed varies between 300kbps and 2500kbps.
I plugged into the test socket briefly (actually it was the 1st thing I did as I wanted to see what speed a "clean signal" gave me) and had:
Connection Speed 3498 kbps
Line Attenunation 61.0 db (I think)
Noise Margin: 4.1 db
I'm not panicking yet (unless you think I need to) as I've got an XTE Faceplate on order. I'm concerned thoough that with these line stats and fluctuations this won't even help.
Ah - while typing this I've had a thought. There are 3 or 4 phone extension points throughout the house, none of which are used. They don't have filters on them - no point as I'm getting the XTE. But will this currently be affecting things?
Anybody got any thoughts or comments or suggestions? Is this normal during the 10 days training period?
Message 1 of 7
(1,160 Views)
6 REPLIES 6
Re: Yikes: Just been connected at new address and...
26-11-2009 4:46 PM
Since you intend to fit a filtered faceplate and don't use the other extensions the first thing I would do is disconect all the extension wires from the removable faceplate. Wrap them in insulating tape for safety and tuck them out of the way temporarily. You can then reconnect them to the filtered faceplate at your leisure
Message 2 of 7
(644 Views)
26-11-2009 4:58 PM
That's a good idea! is that why you have a long white beard?
From memory, that means disconnecting wire number 3? I wasn't going to re-read the intricacies of faceplate wiring until I got the new faceplate.
btw - what's to stop me staying connected to the test socket?
yikes no.2 :- noise margin now 23 and holding steady for last 30 mins.
Message 3 of 7
(644 Views)
26-11-2009 4:59 PM
No just disconnect the lot.
However there is no reason why you can't stay connected to the test socket
Message 4 of 7
(644 Views)
26-11-2009 5:07 PM
Think I'd better head over the the DSL Nation forums and do some reading again. I'm sure when I installed the faceplate at my old house a few years back I only disconnected wire 3.
I still want my master socket "live" for phone use (and sky).
Hope my connection doesn't drop while reading up though !
Message 5 of 7
(644 Views)
26-11-2009 5:12 PM
Confusion reigns
When connecting the new faceplate you only connect the wires to connections 2 and 5
Temporarily - if you don't use the other extensions disconnect all the wires and only reconnect the ones to 2 and 5 when you get the new faceplate.
This enables you to use the existing faceplate with a filter.
However you can also use the test socket with a filter for your phone and Skybox
Message 6 of 7
(644 Views)
26-11-2009 5:40 PM
Actually, if you are using a filtered faceplate you should connect 3, because you are not using filters anywhere else, phones that need the bell wire will not ring otherwise (remember a filter generates a bell wire locally at the filter - as does the filtered faceplate - so to speak). But as Jim says, if you are not using a socket don't connect any of it's wires, tape them up for later in case you want them.
Message 7 of 7
(644 Views)
