Yet more broadband speed confusion
- Re: Yet more broadband speed confusion
05-11-2007 11:41 PM
Looking through the threads on this forum has prompted me to try several avenues but I haven’t managed to get answers on any of them myself so I’d appreciate some advice on where to start looking.
According to http://www.top10-broadband.co.uk/ my local telephone exchange is capable of an “up to 8Mbps” service and I live less than 50 metres away from it so I’ve discounted that as a source of problems. (OK I may be optimistic but you’ve got to start somewhere!)
All the phone ports in the house are filtered.
I’ve tried to get test results from http://www.speedtester.bt.com/ but haven’t seen any results comparable to others on this forum. After entering my phone number and not being asked for a user name, it re-directs me to a different speeedtester site which gives me an average download speed (805kbps) but no information on IP profile. I can’t tell therefore what BT thinks my connection speed is so does anyone know how I can find this out? (I tried to do this test more than once and got a very tetchy message telling me that I couldn’t do 2 tests < half an hour apart!)
I leave my broadband connection permanently on. I do an occasional re-boot say every 5 or 6 weeks but no more than that. Is this likely to affect my connection speed?
Does anyone have any suggestions please on how I should investigate this further?
Thanks in advance for any help.
06-11-2007 12:09 AM
If you post your router stats (sync speeds/data rates, noise margins and attenuations (Downstream and Upstream)) it will help us to provide better advice.
06-11-2007 9:33 AM
ADSL Link Downstream Upstream
Connection Speed 1152 kbps 288 kbps
Line Attenuation 6 db 5 db
Noise Margin 31 db 26 db
Any suggestions?
06-11-2007 9:37 AM
06-11-2007 10:10 AM
06-11-2007 10:33 AM
06-11-2007 11:11 AM
06-11-2007 12:46 PM
06-11-2007 12:51 PM
That's generally the recommended action, yes. I'd also advise turning your router off when you go to bed tonight for optimal results.
07-11-2007 8:59 AM
Connection Speed 8128 kbps 448 kbps
Noise Margin 10 db 21 db
I'll keep doing the daily re-boot but I've already noticed a significant speed increase on internet access.
Thanks guys for all the speedy help, it's much appreciated.
07-11-2007 9:05 AM
07-11-2007 10:53 AM
BT are yet to have set a profiled speed for you at their, but I've preempted the likely profile being set at a maximum of 7150Kbps and I've mapped this at our end.
If you reboot now, you may see higher throughput, but you may need to wait a little for BT to amend their profiling.
