(Yet another) SNRM reset request
- (Yet another) SNRM reset request
25-02-2013 5:36 PM
My line seems to have been fairly stable for a couple of weeks since I corrected a re-done extension - the last three re-syncs (that I know of) being initiated by me (one during disconnection of the ring wire and the last, 3 days ago, to see if a re-sync would change the speed/SNRM). FEC errors are high (last check: up to 7000 per second when idling, none while downloading ), but CRC and HEC change quite slowly (last check: 0 in 6mins, with a 12MB FTP download run in that time).
Hopefully, a reset will up the speed by 12% (to 3.6Mbps ) with the SRNM going to 6dB.
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Message 1 of 3
(1,048 Views)
2 REPLIES 2
Re: (Yet another) SNRM reset request
26-02-2013 9:26 AM
I've placed the SNR reset on your line, this should take around 4 hours to complete.
Let me know how you get on.
Chris
Chris
Message 2 of 3
(282 Views)
26-02-2013 11:24 AM
Thanks, Chris.
Just checked and am now at 3687k/3.9dB and 704k/6.3dB with 66 CRC and 713 HEC over 1h 47m 7s
Attn has gone up (obviously) to 61.8 as it's now using tones up to 159
At 8dB down it kept within 0.2dB, so fingers crossed it can hold when the levels drop later today.
Phil
Quick update: now at 7dB up, 173 CRC, 2294 HEC and 3h 5m 19s
Phil
Message 3 of 3
(282 Views)
