Yes or no. IP Profile.
- Yes or no. IP Profile.
- « Previous
- 1
- 2
- Next »
Re: Yes or no. IP Profile.
01-11-2010 4:29 PM
Hi Barrytrcy,
I'll take a look for you and get back to you when I have more information.
Jojo
Jojo
Message 16 of 21
(304 Views)
01-11-2010 4:43 PM
Alright thanks.
Message 17 of 21
(304 Views)
01-11-2010 5:32 PM
Hi Barrytrcy,
I've just spoken to one of the faults team and they will be contacting you this evening with some further updates.
Jojo
Jojo
Message 18 of 21
(304 Views)
02-11-2010 5:05 AM
Just did a morning BT Speed Test, old ones then the new ones.
OLD
Download speedachieved during the test was - 1966 Kbps
Additional Information:
Your DSL Connection Rate :2912 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 2500 Kbps
NEW
Download speedachieved during the test was - 2161 Kbps
Your DSL Connection Rate :4768 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 4000 Kbps
Now I see why Plusnet won those rewards. Seems the SNR reset worked like a charm. Will keep you posted over the next few days to see how the connection is.
So far so good. Now I just need to wait for the plusnet IP Profile to up a notch.
OLD
NEW
Message 19 of 21
(304 Views)
02-11-2010 9:08 AM
Hi Barrytrcy,
Plusnet and BT profiles now 4000. If you disconnect then connect via your router homepage you will see the increase.
Jojo
Jojo
Message 20 of 21
(304 Views)
02-11-2010 1:03 PM
Alright thanks, will do that now.
Message 21 of 21
(304 Views)
- « Previous
- 1
- 2
- Next »
