Yes, additional speed issues.
- Yes, additional speed issues.
Re: Yes, additional speed issues.
24-06-2011 4:05 PM
Now that's clear then, I'll look at sorting your speed out. Watch this space!
Jojo
24-06-2011 5:18 PM
Your SNR was really high at 34dB, probably because of you phone fault. I've now reset the SNR to 6dB, so once that takes effect you should see an increase in your sync rate, which will then increase your speed profile.
Jojo
25-06-2011 3:05 AM
While the ping has improved, the overall download rate has left much to be desired. I appreciate that there is a teething period whilst setting up a new connection, but surely it shouldn't be this bad for this long? I'm having trouble simply enjoying my time on the internet. I've just returned home from a night shift and it is at this time (while overall traffic should be completely low) that download speeds are the most valuable to me. After all the hassle of switching over, it can't be too much to ask for a stable connection at three in the morning?
25-06-2011 7:14 AM
25-06-2011 10:26 AM
25-06-2011 12:23 PM
25-06-2011 1:30 PM
25-06-2011 4:55 PM
25-06-2011 9:35 PM
27-06-2011 2:51 PM
Your line had been banded, so the sync rate wouldn't have gone above 1152k. I've had this lifted now and your sync is 6744, so when your profile lifts you should see a profile of 5500.
Jojo
28-06-2011 11:17 PM
*EDIT* Well, the internet is back, after a fashion. I have ridiculously inconsistent connection, as well as terrible speeds. Took about 10 minutes for the 'modify' page to load on this message. What on earth is going on?
28-06-2011 11:49 PM
The connection test page on the TG585 router, always shows red crosses against DNS - it's a reporting problem, not indicative of a fault with DNS.
Just tried post "modify". Loaded normally for me.
29-06-2011 12:36 PM
I think the best thing to do at this time is to update your fault ticket so this can be investigated further.
Jojo
30-06-2011 1:55 AM
30-06-2011 9:39 AM
Hope that helps,
