Quote from: moarjin |
After weeks of trying, I gave up trying to get my line speed back after I switched, I now just live with awful reliability, where networks simply refuse to "talk to each other" (like this xbox live issue), despite there being nothing wrong with my line and line speed.
Can I ask what modem/router you are using?
Can you hear/have you heard any crackling or other noises on the line when using the phone? Have you had any problems with incoming or outgoing calls? Try the Quiet Line Test 17070 option 2 if need be.
Do all your
Microfilters look similar to this?
Do you have any extension phone sockets, and what is normally plugged in where?
At the moment, I'm a bit puzzled why you are having so many problems as you said you had flawless service when with BT which would be using the same exchange equipment (and same line of course) neither of which are Plusnet specific. I'm wondering if the line has developed an intermittent fault, or something else is faulty.
