Xavi 7768r modem/router setup - help!
- Xavi 7768r modem/router setup - help!
15-09-2007 9:57 PM
It seems to get an ADSL connection, but nothing works. I have found one error message that says "LCP negotiation would not converge"
Thanks!
Re: Xavi 7768r modem/router setup - help!
15-09-2007 10:07 PM
Which settings did you use to set it up?
15-09-2007 10:10 PM
You are right about the non standard setup - much more complicated than my Linksys one that has partially died on me.
I've tried to follow the Plusnet guidelines as far as I can to create a PPoA link. However, the options offered on the Xavi box are legion and it do not use the same terminology - so rather confusing.
15-09-2007 10:15 PM
15-09-2007 11:34 PM
15-09-2007 11:36 PM
15-09-2007 11:37 PM
15-09-2007 11:38 PM
16-09-2007 12:12 AM
I hate the Xavi routers setup
16-09-2007 8:18 AM
The Wan status puzzles me, since the ONLY connection that exists is configured as PPoA. I'll see if there is some way I have missed for specifying which connection it should refer to.
16-09-2007 10:36 AM
17-09-2007 8:35 AM
Mine originated in Spain (Telefonica) and I'm wondering if that means there is something about it that is profoundly incompatible with the UK?
17-09-2007 10:42 AM
I'll dig them out and post a link soon.
17-09-2007 11:09 AM
17-09-2007 12:20 PM
Also, should NAT not be set to true too?
You could try this setup video, changing the settings to suit your PN ones, of course
