X where teapot used to be
- X where teapot used to be
- « Previous
- Next »
Re: X where teapot used to be
07-10-2008 6:30 PM
It's odd because it works fine here.
Java : 1.6.0-07 b06
Firefox 3.0.3
See attached screen print.
Java : 1.6.0-07 b06
Firefox 3.0.3
Message 31 of 37
(490 Views)
07-10-2008 6:34 PM
this is all I get
Firefox 3.03
XP SP3
Java just been updated
Java Plug-in 1.6.0_07
Using JRE version 1.6.0_07 Java HotSpot(TM) Client VM
User home directory = C:\Documents and Settings\
java.lang.NumberFormatException: null
at java.lang.Integer.parseInt(Unknown Source)
at ProgressBarPT.getIntValue(ProgressBarPT.java:181)
at ProgressBarPT.init(ProgressBarPT.java:199)
at sun.applet.AppletPanel.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Firefox 3.03
XP SP3
Message 32 of 37
(490 Views)
07-10-2008 6:46 PM
I also have the previous versions installed as well.
I know that sometimes you need the older versions of Java (like .net) for some programs to run.
Jeff
Jeff
Message 33 of 37
(490 Views)
07-10-2008 6:52 PM
and they said it work work with al that detritus about
Message 34 of 37
(490 Views)
07-10-2008 8:46 PM
I have just renewed my java install but still same.
Message 35 of 37
(490 Views)
07-10-2008 9:26 PM
Techguy
Have you cleared your Java cache?
Message 36 of 37
(490 Views)
07-10-2008 9:39 PM
cleared Cache no change, but how does yours work with all those old Java's about?
Message 37 of 37
(490 Views)
- « Previous
- Next »
