X where teapot used to be
- X where teapot used to be
03-10-2008 9:24 PM
Re: X where teapot used to be
03-10-2008 9:28 PM
03-10-2008 9:30 PM
03-10-2008 9:37 PM
I cant run a full test as don't have the line's phone number (such things are known to managers only round here)
03-10-2008 9:43 PM
Why does the BT speedtest not keep up with the Java?, just about to test but my Mini Linux job, I cant change the Java and that works usiually
03-10-2008 9:49 PM
03-10-2008 9:52 PM
Java Plug-in 1.6.0_07
Using JRE version 1.6.0_07 Java HotSpot(TM) Client VM
03-10-2008 9:54 PM
edit: hmm I should have checked in IE before replying first, looks like the site is broken or changed, fails to load in IE as well now with the same issue
03-10-2008 10:03 PM
03-10-2008 10:41 PM
03-10-2008 10:58 PM
04-10-2008 11:04 AM
Being a rocking horse it leaves me coldm but if any of you can find something there, please tell the likes of me in simple terms.
04-10-2008 1:28 PM
Click Advanced tab and scroll to security at the bottom of the lst, make sure that the option to allow active content to run in files on my computer is ticked.
Please also disable/uninstall all toolbars as these can cause issues as they often include script blobking/pop-up blocking.
Also in my experience, some Internet Security products with script blocking/heuristic behaviour analysis can cause problems with legitimate scripts, so switch off these specific features before running these tests.
04-10-2008 1:31 PM
04-10-2008 3:23 PM
