Wrong router delivered
MrDodge
I have just had fibre installed, and I think that PN have sent me the wrong router package as it contains ADSL microfilters, and no cable with red plugs.
It is however a TG582n router, which I believe is the same box that is supposed to be sent to fibre customers.
So... is it possible to get the TG582n  working with fibre using an old ethernet cable I have instead of the red cable? I have tried to connect it up, but it didn't work.
The green broadband light didn't stop flashing, and when I got to the router login page it didn't accept the router access password that I have received.
Do I need to get another router from PN?
thanks in advance for any tips. currently using PC connected directly to Openreach modem. That works fine.
10 REPLIES 10
picbits
Re: Wrong router delivered
There are posts on here somewhere with links to the firmware to reflash it to become a FTTC router.
w23
Fixes: 4
Have a look at: http://community.plus.net/forum/index.php/topic,104892.msg894902.html#msg894902 (the links in Matt's post: possibly rather old firmware since the post was a good while ago)
See also http://community.plus.net/forum/index.php/topic,104892.msg894902.html#msg894902
Call me 'w23'
Fixes: 385
The router access password is the serial no, it's printed on the underside of the router.
MrDodge
Yes, that the same number that I have on the card. The router doesn't accept the number.
dick:quote
Fixes: 385
Very strange!. I could perhaps see how the wrong card was supplied but AFAIK the default settings of the router will use the s/n. Is it possible you're confusing O's with zeros ?
Also try a factory reset
While the unit is on, hold down a thin object such as a paper clip into the reset hole at the back next to the power button until the power light on the unit goes off. Release the reset button.
  and then see if it will accept the password
w23
Fixes: 4
Don't forget, the password is 'CaSe SeNsItIvE'
Call me 'w23'
apjashley1
Does it have a USB port on the side?
Also try "Administrator" (note capital A) and leave the password box blank.
MrDodge
thanks for the replies peeps. I have confirmed with plusnet support that they sent out the wrong router, and am getting another one. Not sure I'm brave enough to try re-flashing the box I have! if it doesn't work, it'll be useless for anything...
w23
Fixes: 4
... except a doorstop.  Wink
Call me 'w23'
Chris
Legend
Fixes: 169
Sorry about this, I can see we've posted the correct router out now to you. The incorrect one was sent by human error, so shouldn't be a widespread issue.
