Wrong profile on Plusnet fibre
SoccerTees
Hi
My Plusnet fibre just went live a few minutes ago (switching from Sky Fibre). However, I seem to be on the wrong profile - 40/20?
Could you please reset it to the correct 80/20 profile. Spoke with someone on the phone and they advised it can't be done before 10 days due to DLM. Think he was confusing it with ADSL.
Also, is there any possibility of turning the interleaving off to improve my latency or to be put on fastpath.
Thanks  Smiley
SoccerTees
Re: Wrong profile on Plusnet fibre
Seems to have settled on a better speed, however I can definitely get higher.
Speedtest.net shows:
However, I can get:
So any possibility of nudging my profile up please.
Also, the ping is really really bad. Any way we can make that better?
Thanks.
what do you get if you ping bbc.co.uk?
Call me 'w23'
SoccerTees
Quote from: w23
Sad
Hi SoccerTees,
Your profile on our side is at 78000 so it's not being slowed down by us. As it's newly installed though it will take a couple of days to settle down.
Regarding the pings, 30ms certainly isn't a high ping and shouldn't be causing any problems with your use of the service. Where is it you're noticing the high pings - on any particular protocols or sites, and if so how is it affecting your use of the service?
Does look a bit higher than others get on fibre (I know mine's interleaved both down and up but my ping's nearly 10ms lower than that) - though as Matt says it shouldn't really be noticable as long as it's consistent (except on tests!).
Unfortunately Plusnet (same as any other ISP using BT based FTTC) cannot change interleaving status (not without a BT engineer anyway) as no control on the cabinet DLM is available to ISPs.
Your speeds are actually pretty good (the throughput will never be as high as the sync speed or 'line rate' as the checker puts it).  If the line remains stable with low error rates for a good while the cabinet DLM will switch to fastpath.
Call me 'w23'
SoccerTees
Quote from: Matt
Hi SoccerTees,
I haven't tested it with any games etc but there's a slight lag while using facetime with someone in Australia.
I was with Sky fibre till this morning and I was consistently getting between 13-15 ms pings. This is double that.
Any idea on how to get this down or should I wait for a couple of days and then check again?
Thanks.
Plusnet Staff
Plusnet Staff
Fixes: 159
I'm not surprised!
32ms is tiny, you wouldn't notice a difference between 15ms and 32ms in reality.
The ping *may* decrease, but to be honest the line is performing well within expectations.
 Chris Parr
 Plusnet Staff
SoccerTees
I'm sorry but this is just unacceptable and not what I signed up for. I want it fixed NOW !!
Just kidding. Hopefully it will improve in a few days/weeks else as Chris said, not really a huge difference between 15 and 30ms and barely, if at all, noticeable.
Thanks everyone for your help and input
  Smiley
Fixes: 10
Running speedtest.net tests on Australian servers and comparing the latency when running on UK servers suggests a 300ms latency overhead. Compared to that, the difference between 15 and 30 is totally insignificant!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
SoccerTees
Yeah. Just tested and hopefully the DLM will set it right. Else no big loss.
Just tried a download on usenet and getting a constant 9MB/s over wifi. Might even increase when the speed settles in a couple of days.
Happy Days  Grin
