Wrong profile on Plusnet fibre
- Re: Wrong profile on Plusnet fibre
12-12-2013 2:06 PM
My Plusnet fibre just went live a few minutes ago (switching from Sky Fibre). However, I seem to be on the wrong profile - 40/20?
Could you please reset it to the correct 80/20 profile. Spoke with someone on the phone and they advised it can't be done before 10 days due to DLM. Think he was confusing it with ADSL.
Also, is there any possibility of turning the interleaving off to improve my latency or to be put on fastpath.
12-12-2013 2:35 PM
12-12-2013 2:47 PM
12-12-2013 3:01 PM
Quote from: w23 what do you get if you ping bbc.co.uk?
12-12-2013 3:59 PM
Your profile on our side is at 78000 so it's not being slowed down by us. As it's newly installed though it will take a couple of days to settle down.
Regarding the pings, 30ms certainly isn't a high ping and shouldn't be causing any problems with your use of the service. Where is it you're noticing the high pings - on any particular protocols or sites, and if so how is it affecting your use of the service?
12-12-2013 4:04 PM
Unfortunately Plusnet (same as any other ISP using BT based FTTC) cannot change interleaving status (not without a BT engineer anyway) as no control on the cabinet DLM is available to ISPs.
Your speeds are actually pretty good (the throughput will never be as high as the sync speed or 'line rate' as the checker puts it). If the line remains stable with low error rates for a good while the cabinet DLM will switch to fastpath.
12-12-2013 4:28 PM
Quote from: Matt Hi SoccerTees,
I haven't tested it with any games etc but there's a slight lag while using facetime with someone in Australia.
I was with Sky fibre till this morning and I was consistently getting between 13-15 ms pings. This is double that.
Any idea on how to get this down or should I wait for a couple of days and then check again?
Thanks.
12-12-2013 4:33 PM
Quote slight lag while using facetime with someone in Australia.
I'm not surprised!
32ms is tiny, you wouldn't notice a difference between 15ms and 32ms in reality.
The ping *may* decrease, but to be honest the line is performing well within expectations.
12-12-2013 4:48 PM
Just kidding. Hopefully it will improve in a few days/weeks else as Chris said, not really a huge difference between 15 and 30ms and barely, if at all, noticeable.
Thanks everyone for your help and input
12-12-2013 4:52 PM
12-12-2013 5:03 PM
Just tried a download on usenet and getting a constant 9MB/s over wifi. Might even increase when the speed settles in a couple of days.
Happy Days
