Wrong place for server details on webmail
- Wrong place for server details on webmail
07-12-2009 3:00 PM
Very, very rarely do I need to log in to webmail to read my email so to have the server choice several lines below the login butten (even after the location for comments) is to me most illogical, especially after two attempts to login (ps I use Force9)
Message 1 of 2
(792 Views)
1 REPLY 1
Re: Wrong place for server details on webmail
07-12-2009 3:10 PM
I suspect it's the default positioning of the plugin we use for that particular drop-down. I'll ask around and see whether or not it's easily moved.
You can set a cookie that will remember your choice though by using the 'Remember login server' checkbox.
Whilst we there, we should probably remove the outdated link to the forums too.
Edit: I'm told that we're looking to revamp the login screen, and when we do we'll take into account your feedback and make sure the domain drop-down is aligned more appropriately.
Message 2 of 2
(348 Views)
