Wrong line profile
- Re: Wrong line profile
06-04-2024 11:50 AM
Bridge taps are unterminated extensions of the telephone line or loop. They can alter the impedance of the local loop, especially at ADSL & vDSL frequencies. With DC (AC when the phone rings!) voltage the bridge tap behaves like an open circuit (so no effect), but with high frequencies (ADSL & vDSL), the loop becomes a transmission line "stub". This impedance mismatch can cause a wide variety of problems, but typically it causes a reflection of data bits from the tap-point back to the point of transmission. This results in bit errors, or in English, your speed will most probably reduce.
A bridge tap can affect the speed at the test socket if the wiring is not correct. If wired correctly, Extensions SHOULD be disconnected when the test socket is being used.
Wonder if a bridge tap can be caused before the test socket, where it was repaired in the driveway after being severed 4 years ago.
Assuming the repair was done by Openreach then it shouldn't...
06-04-2024 11:53 AM
06-04-2024 12:54 PM
Whilst my money would be you being provisioned, or you are stuck due to a software glitch, on the 40/10 service, another question: Are you on a static IP address?
06-04-2024 1:00 PM
06-04-2024 3:37 PM
I can see you spoke with a colleague today who's raised a request to reset your DLM profile
Have you noticed any difference?
06-04-2024 3:39 PM
06-04-2024 3:55 PM - edited 06-04-2024 3:56 PM
@MatthewWheeler given that the DLM reset didn't restore @alicelight80 's speeds,
can you check that @alicelight80 has been provisioned on 80/20 SoGEA. and not 40/10 ?
as it looks unusual that their router download "Data Rate:" is exactly at 40Mbps,
given that the corresponding "Maximum Data Rate:" is quite a bit higher !
06-04-2024 4:41 PM
Hmm, well I think my tech finished his shift at 4.30pm and no promised call back received .
Should I text ADVISOR again and run the risk of getting someone who wants to start from the beginning and film my test socket?
Many thanks
06-04-2024 4:44 PM - edited 06-04-2024 4:45 PM
@alicelight80 I wouldn't start the process again - Plusnet are aware and should be monitoring what is happening - but note the 'should'.
@MatthewWheeler You still around to investigate, please?
06-04-2024 8:01 PM
Just noticed router dropped connection and re-connected higher, particularly upload, though download still below the handback threshold of 57mpbs on this 80 line - wonder if it'll improve or regress... (previously was stable at max 35 down, 7.5 up, data rate profile was 40 down, now 50)
06-04-2024 8:03 PM
Oh the noise margin has changed too
06-04-2024 8:38 PM
That is looking much better, @alicelight80 . Noise margin back where it should be - roughly - and speeds creeping up, although you might get a couple more 'blips' as your speed (hopefully) gets above the H/B threshold.
Do you still have an engineer planned to check the bridgetap issue?
06-04-2024 8:43 PM
No engineer planned as nobody got back in touch today following the reset - I can see DLM is trying to do its thing. I guess I'll wait a few days and chase if my download is much less than 57mbps, though maybe negligible in real life use.
Really pleased with the upload speed so far anyway; we both work from home on local government VPN including lots of file uploads / downloads, including AutoCAD, so I think husband in particular will notice a difference in sending large files.
06-04-2024 8:47 PM
OK. The bridge tap does need investigating though, as until it is rectified you may find things regressing again. See how things go tomorrow, and if you don't get an engineer visit offered, come back and lets see if we can get one arranged.
06-04-2024 8:48 PM
Ok will do, that makes sense, thanks for your help
