Would be very grateful if this can be investigated
- Would be very grateful if this can be investigated
14-08-2015 5:51 PM
Have been experiencing drop outs in the last five days. After speaking with customer services my phone line and internet was restored since Thursday.
However the speed I am getting is very difficult to use (approx 0.5 mb, where usually it is stable 10mb). Currently awaiting response to this on my ticket. Would be grateful for any input here?
DSL Connection
Link Information
Uptime: 0 days, 0:07:56
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 440 / 572
Data Transferred (Sent/Received) [MB/MB]: 2.66 / 22.37
Output Power (Up/Down) [dBm]: 12.3 / 0.0
Line Attenuation (Up/Down) [dB]: 18.9 / 34.0
SN Margin (Up/Down) [dB]: 28.9 / 27.5
Loss of Link (Remote): -
FEC Errors (Up/Down): 0 / 840
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
Bt wholesale test
download 0.46
upload 0.3
ping 80.38
Estimated line speed:
Current line speed:
0.5 Mb
DSL Connection
Link Information
Bt wholesale test
download 0.46
upload 0.3
ping 80.38
Current line speed:
0.5 Mb
Message 1 of 3
(611 Views)
2 REPLIES 2
Re: Would be very grateful if this can be investigated
14-08-2015 6:20 PM
Just spoke with customer services, she said she will try to improve the speed and this should show up in 4 hours.
>>though the texts i received said they would take steps to improve stability which could result in decrease to the speed
Hopefully this will give usable internet speeds so thanks to Hannah at customer services. But I would add it is somewhat frustrating that i submitted three replies on my ticket over the last two days with no response. But then a 5 min phonecall may resolve my problem.
Message 2 of 3
(345 Views)
17-08-2015 11:07 PM
Has this been sorted? If not, have you power-cycled the router, as your downstream noise margin is tremendously high.
Get a decent connection speed, then you would probably have to wait overnight for an updated BT IP profile, then a few hours for the Plusnet copy to catch up.
Message 3 of 3
(345 Views)
