Would adding the pro to fibre unlimited stop the peak time slooow downs ?
- Would adding the pro to fibre unlimited stop the...
- « Previous
- Next »
Re: Would adding the pro to fibre unlimited stop the peak time slooow downs ?
25-01-2014 5:09 AM
The previous 2 nights have been ok, almost full throughput both upstream and downstream and it's more or less consistent , and looking at the ping monitor there is an improvement in the peak time jitter (Yellow spiking ) in that it's a lot lower than it has been, So a good 2 nights so far ,
But as said it seems to be Sunday & Monday nights occasionally Tuesdays or Wednesdays too, if ok on a Sunday
26-01-2014 9:11 PM
This has to be a BTwholesale issue with capacity to yourselves a internal plusnet issue, or a peering issue(capacity) has this been raise with anyone (like bt wholesale ect ?)
Also i find the small red spike interesting that appeared at around 7pm this also is visible on another plusnet customers ping monitor ,so not unique to me, change of internal routing per chance on to a congested pipe perhaps?
Oh and to anyone else who may read this, I'm not being unreasonable or just having a go, if the quality of service i receive is reliable 24/7 like i have experienced in the past i will say so, just as i have no qualms in telling how it is good or bad ,as i'm sure most will have realised by now. but nothing gets done if you don't do anything about it ,again equally obvious i know
27-01-2014 8:53 AM
27-01-2014 12:26 PM
27-01-2014 1:09 PM
Ex-Broadband Service Manager
27-01-2014 1:13 PM
27-01-2014 7:12 PM
29-01-2014 12:27 AM
and the tcp connections are marked the same in both utorrent and http only the upd are different in utorrent ,the difference in throughput between normal http and torrents wasn't a lot, i think there is a possibility that http traffic is being marked incorrectly causing the downstream slowdowns or contributing to them certainly last nights experience, oh i got the BT wholesale speedtest to offer a tap3 test, and so matter what i tried it would not connect using the login given speedtest@speedtest_domain so i was unable to do the test to rule out plusnet
02-02-2014 9:00 PM
12-02-2014 9:24 PM
Have BTW reported back on this, or has nothing been done about it yet,?
12-02-2014 9:34 PM
12-02-2014 9:44 PM
And last night shows a similar pattern
13-02-2014 9:04 PM
http://www.thinkbroadband.com/speedtest/button/139215290278776825470.png 21:09
http://www.thinkbroadband.com/speedtest/button/139215628239143431052.png 22:06
http://www.thinkbroadband.com/speedtest/button/139216028202452544803.png 23:10
12/02/14
http://www.thinkbroadband.com/speedtest/button/139222787055395965030.png 18:00
http://www.thinkbroadband.com/speedtest/button/139223464623921073680.png 19:50
http://www.thinkbroadband.com/speedtest/button/139223909582190073758.png 21:05
http://www.thinkbroadband.com/speedtest/button/139224231776022475683.png 22.00
http://www.thinkbroadband.com/speedtest/button/139224419424348252804.png 22:30
13/02/14
http://www.thinkbroadband.com/speedtest/button/139225831823199884068.png 02:25
http://www.thinkbroadband.com/speedtest/button/139229383343695191386.png 12:15
http://www.thinkbroadband.com/speedtest/button/139231520329345068727.png 18:15
http://www.thinkbroadband.com/speedtest/button/139231836237671526246.png 19:05
http://www.thinkbroadband.com/speedtest/button/139232368141790322522.png 20:35
FTP upload throughput is again under 50% of the max possible
- « Previous
- Next »
