Would a faceplate filter improve my speed?
- Would a faceplate filter improve my speed?
Re: Would a faceplate filter improve my speed?
22-02-2013 3:00 PM
Quote from: Anotherone Star wiring makes NO difference HP. That wiring standard is fine.
Well in my experience it most definitely does.
Quote from: DaddyG Would the option of running cat5e from the master socket be even faster than that?
Probably not much if at all, unless the existing extension wiring was sub-standard or passed a significant source of interference.
(We're talking about an extra 15m at the end of nearly 2km from the exchange)
22-02-2013 3:02 PM
22-02-2013 3:02 PM
14Mb (This may vary between 12.5Mb and 16Mb) - Checked on 2013-02-01 14:13:16
Current line speed:
8.9 Mb
22-02-2013 3:03 PM
22-02-2013 3:07 PM
You should see a PPP drop when that takes effect (not a sync drop) DaddyG.
By the way, as far as not having a disconnect PPP on a modem/router for the Disconnect procedure, the next best thing is to pull the power plug and wait a minute before disconnecting things.
22-02-2013 3:37 PM
Download speedachieved during the test was - 15.23 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 15.72 Mbps
Fantastic! Thanks a lot for all your help guys
I think I'm going to have a go at setting a WAP up anyway, as the wireless signal at the front of the house is rubbish.
This will obviously involve turning the router on and off a few times. Will pulling the plug out stop my SNR getting downgraded again?
22-02-2013 3:54 PM
Presumably you're talking about using the spare unit as a WAP, you can set that up and test it without doing anything to the main router at all other than plugging an extra cable in to link the two once you've configured it offline and are ready to test internet connectivity.
22-02-2013 4:13 PM
There will be some down time whatever way I do things. My Cat5e should arrive tomorrow, should I hold off a bit before unplugging anything again? And if so how long should I keep it running?
22-02-2013 4:25 PM
Out of interest what are you planning to do overall?
Many of the things mentioned can have significant effects, some less so and many are just "tidying up" but a well-organised installation will be less prone to problems and easier to diagnose should they occur.
22-02-2013 4:41 PM
There is an old co-ax cable already running most of the route, so I'm going to pull that out and run the Cat5e through the hole. I should only have to drill one wee hole, and can run the cable pretty much unseen to the router.
I'm happy with the speed I'm getting now, so will only really be doing this for the additional wi-fi range.
Does that sound like it would work?
Also, I may still get a faceplate filter, just to tidy things up. Plus I'm curious to see if there is any additional speed
22-02-2013 4:48 PM
They can be fitted without undoing any wiring (just 2 screws) and work really well - I have one myself.
See: http://phil.lavin.me.uk/2012/02/bts-uk-fttc-vdsl2-explained/ and http://www.clarity.it/vdsl_nte5_adaptor_faceplate.htm
22-02-2013 4:50 PM
But as I mentioned earlier, I'm trying to save as much money as possible just now. I've got a punch down tool and don't mind a bit of re-wiring, would this do the job as well?
http://www.amazon.co.uk/ADSL-Faceplate-Filter-Master-Socket/dp/B0030BC2PW/ref=pd_sim_ce_3
22-02-2013 5:01 PM
The new BT one is very neat and clever though a tiny bit bulkier. You can get them for under £10 on eBay.
With your plans I'd say get the BT one unless you have a specific reason not to.
22-02-2013 5:15 PM
22-02-2013 9:01 PM
I think even RR would agree with that
